John Morris Lifetime Supporting Member J Join Date Sep 2015 Location San Antonio Posts 689 Nov 19, 2021 #1
Operaghost Member Join Date Apr 2002 Location Dallas, TX USA Posts 4,107 Nov 19, 2021 #2 I will assume this is Allen-Bradley/Rockwell Logix 5000 software. The "1" indicates that the routine is the Main Routine for that program. OG
John Morris Lifetime Supporting Member OP J Join Date Sep 2015 Location San Antonio Posts 689 Nov 19, 2021 #3 Any idea how to change it to the Main Routine i want Found one way Delete all program files from under "Logic and Tags, and start over. the first program will give the option to become the main program Thank you Ghost Last edited: Nov 19, 2021
plvlce Lifetime Supporting Member P Join Date May 2017 Location Michigan Posts 1,074 Nov 19, 2021 #4 John Morris said: Any idea how to change it to the Main Routine i want Click to expand... Remove any JSRs that call the routine you want to become the main routine. Then right-click the program in question, select 'Properties', go to the Configuration tab, and select it as the assigned main routine.
John Morris Lifetime Supporting Member OP J Join Date Sep 2015 Location San Antonio Posts 689 Nov 19, 2021 #5 Thank you plvlce
