What Exactly Is Needed To Run WinCC 7.0
hein123
Aug 2010
Uitenhage
93
Hi again
What is needed to run wincc 7.0 of a IPC477 PC using TCP/IP with a 319 PLC?
I have tried everything exact the way that does work :)
I know how to create a tag and setup a connection is just the part to actually connect. I know my communication parameters on the PC is correct as I can connect to the PLC when using WinCC Flex.
Please any advice would be appreciated
That problem my fixed, now I have another problem :)
When I do a basic project on my laptop and then just transfer the program to the IPC panel pc, it does not want to run.
It show that I can't run the program because I do not have access, but I am admin
Any suggestions?
The WinCC project MUST have the same name of your new PC. This might be the problem.
I have sorted the problem. After naming everything (PC / DOMAIN, etc) exactly the same. Still no luck.
However the solution was to copy the entire program (STEP 7 + WINCC) and then place them in exactly the same folder.
THis was the solution :)
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
153
Hi all, New grad working with PLCs for the first time. Today I came across the concept of scheduling when adding new devices to a ControlNet...
1,114
So we are trying to read 3 meters on our line from a webpage. The 3 meters are on the network going to a PLC which is properly configured to read...
4,758
What exactly can you do with 1784-U2DN? I am looking to connect a PC to the DeviceNet to run security penetration testing. That's how I found...
1,821
I am looking for a small control box (sub 12"x12"x8") in size that is hinged but instead of the hinged door being only a an inch or so the hinge...
1,984
