What is contained in RSLogix 500 CIP Path
zacslade
Oct 2014
Phoenix, AZ
84
Hi All,
In RSLogix 500, under Controller Properties, in the Controller Communications tab, the "CIP Path" is stored for my controller. This path has the following format:
CIP Path xx.xx.xx.xx.xx.xx.xx.xx.xx.xx.xx.xx.xx
(replace all the "x"s with numeric digits 0-9).
There are 13 two-digit numbers separated by periods. What do those numbers mean? They don't look like the IP address.
Thanks!
I was just curious if there is a way to search for a description of a boolean contained within a DINT/INT. For instance, I have a DINT[1] named...
2,272
Good afternoon all, does anyone recommend any coolant vacuum filter pumps to clean out tanks and get all the sludge and chips out of a...
2,986
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
70
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
106
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
186
