What is equal to the SLC 500 1747-L553B 5/05 Processor in the CompactLogix family ?
Aug 2016
Virginia
343
Good Afternoon,
I plan on replacing some SLC 500 PLC's with CompactLogix. Could you tell me what the equivalent processor is in the CompactLogix family to the SLC 500 1747-L553B/C 5/05 processor.
Thanks so much in advance ,
Probably low-end 5069-L310ER, or 1769-L16ER, what sort of IO does the SLC use and how much? Are you replacing IO or converting the SLC IO racks to Ethernet using a 1747-AENTR?
Are you going to re-write and use Logix features like AOIs, UDTs? Probably going to come down to price and how much memory you want, and the IO system you want to use..
About a total of 11. About 5 - 1746-IB16 , 4 - 1746-OW16 , 2 Analog Output Cards. I would like to use the conversion tool. I imagine the tag-based processors require more mamory , correct ? I would like to be somewhat "robust" and use the 1769-L33ER. That may be an overkill. I also have a PLC 5 that I need to change out.
Have you guys ever run into an issue using GE proficy that sometimes, even after uploading from controller, that the Program and PLC will not be...
1,809
In this project I wanted two pumps to alternate between lead and lag. The controller is a Micro810. I'm using a counter to dictate whether pump 1...
1,105
Hi all, Day two on working on the 90-30 controller I posted about yesterday. I was able to connect to it via Proficy Machine Edition (8.6) and...
1,842
Hello, I need a little help. I’m looking for a way to program integer values to activate a bit for an alarm. for example... If any Integer[0] thru...
41
7,882
Continuing saga from an earlier service call... My customer has a machine with a 90-30 PLC. We couldn't get logic equal by uploading the program...
3,596
