What is the Difference between M and I Inputs ?
Any name
Jul 2018
Dubai
21
Hello,
I want to ask about the difference between I and M Inputs and what is the best situation to use each one of them ?
Thank You
What software?
For Siemens, I is input, M is memory. So M is not an input, but an internal memory address.
What software?
My Software is Siemens TIA portal,
Would you please give me an example ? When i need to Use I. I’m using M in my simulation and it worked very well.
You use I when you want to read an ("physical") input. I0.0 for bit, IW0 for word, etc.
You use Q when you want to write to an output.
These in and outputs can also be remote IO or profibus/profinet devices.
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,415
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,044
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,973
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
815
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,834
