Peter Nachtwey
I don't know if you are observing, boasting or complaining. I know I would not be happy if people asked the same question over and over again about my product. To me that indicates a flaw in design or documentatin.Stephen Luft said:1. It appears that the majority of questions relate to either Allen Bradley or Siemens products.
Same here. We try to have excellent documentation but there are some that just will not even try.We also have customers that will call us with questions that can be answered by simply reading the manual. We continue to answer the same questions, because that is customer support....They ask, we answer...lol.
When I was in college we always asked the upper classmen about the courses and test, but there was also a file that our fraternity had on different classes. Homework problems and tests were submitted to the file cabinet and the freshmen would fight over access to this information. The point is that we were very much aware that the sophomores took the class the previous year.2. Every semester you get a new group of students looking for help, with the same curriculum...therefore the same questions.
exactly, but.....It had been suggested at one time to create an archive section with threads related to common questions asked by students.
That is the million dollar questions.I know this would take time on Phil's part to actually set up. One would have to ask, if it were to be done, would it be used? As mentioned above, "instant everything".
3. It had be mentioned in a previous post that the search function doesn't always produce the most favorable results. I have used the search function only a handful of times, therefore, I don't believe I can comment as to it's effectiveness.
as stated above it is best to type the name of the person and the key words.
A lot of the time products from different manufacturers must work together which is often what we see. How is each manufacturer going to document all the different combinations?You had also mentioned that with new products, come new problems. Even with existing products that have been revised, new problems arise. I believe this relates to point one - the documentation provided by the manufacturer and access to their support system.
That would be a good poll and it gets back to one of my other favorite topics about support. Some people think that support means reading the manual to them. Other think it is for the weird undocumented things that happen. In this case Stephen has it easy. Rockwell and Siemens that have so many things that can be used with other things they sell that I doubt all the combinations can be tested and I am sure weird stuff happens from time to time. These are the situations where support is needed because no one can document everything. Even if one could would any body have the time to read it all? These are the kinds of problem that are truly firsts.One would have to ask, are the amount of questions related to specific products related to documentation, accessibility to support or a quick fix (or maybe something else). (Casey...I smell a poll - Why do you post your question on the forum?)
I think it is a spiral.The longer you are involved with anything...including life, you will see cycles, repetition and trends. It appears that on this forum, the time is much more condensed because of what is stated above.
