I will have to vote for Entertron
I am a little surprised at the results, but overall, I think it was much as I expected.
As elevmike stated
Now as far as PLCs go... I'm really happy and not in the market. But if a nucular bomb were to land on Cummings GA, then I'd go knocking on Steven Luft's (Entertron) door first.
This seems to echo the thoughts of quite a few members that I have run across this year, most of whom haven't posted here.
I have to say, I did expect to see Entertron a little higher. While I haven't had any hands on experience with Entertron hardware, it is the one I want to try. I have recommended it to several people, and haven't gotten any complints back. I am surpised that I hadn't heard about them years ago, I started with plc's in 1988, and they've been around sine before '80.
I like these Entertron features:
1). Relay Output Ratings - 7 and 8 amps
2). Tansistor Output Ratings - 2 amps
3). Longer Warranty - 6 and 7 years
4). Offline Run Simulator - This is ideal for debugging at home, or for students who don't have a plc. I've had several people comment to me they like this feature.
5). FREE Software (Free Free Free)
6). Resonably priced
7). Master Control Relay feature for blocks
8). A lot of the drum sequencer and other functions.
9). FREE (Good) Tech Support - No membership Dues (Did I mention FREE?)
As I have stated before, if we are ever able to reopen the OEM shop, it will use Entertron. There is a lot of repetitious programs there, for duplex pumps, diesel engine autostart, alarm sequencers, tire building machines, tire presses, etc. There is no need for the customer to get into the program.
Since I seldom have done anything proprietory, the Entertron program protection feature is not something I need, but if I built machinery, that might be a different story. I will say I was pretty upset in the tire plant days when I couldn't get into the "Hummer" tire balancer program, and had to buy to more sixnet plc's ($5,000) to see if the problem was the plc or ??? Never did figure it out, the two new boards never worked, and eventually both old ones did.
I had wanted to try Keyance, but after getting the programming guide books, and realizing that you write the rungs backwards, I changes my mind.
Also, I thought AB and Omron would be a little lower. Also, would have thought AD to be a bit lower, 'cause everyone tried them once. Not much following for GE Fanuc. Overall, I guess I would say pretty representative.
Thanks to all y'all.....casey
For those who are interested, here is the Entertron
"LINK"
