Shifting from PLC to BMS Industry
TahirQ
May 2013
Riyadh
54
Hi guys,
I am planning of shifting from PLC to BMS industry as in my country BMS projects are at their peak right now. Any advice from seasoned pro's, what basic concepts should i get a good grasp of before considering to shift jobs.
Any advice will be appreciated thanks.
Hi, I need to bit-shift a block of words in an Omron PLC by a certain amount. Is SFTR the only way to do this? I've tried NSFR/NSFL but from...
3,698
Greetings, I am trying shift data in an array (such as Array[0] is shifted into Array[1], Array[1] is shifted into Array[2]......all...
365
Hello Guys, I think I need to use SCL for the following task but am very weak using SCL in tia portal. I have results history data block. It is...
3,053
Why encremental encoder have a phase shift of 90°between A,B phases ,if it's 60° 30° what happen what's the difference ,can we change the 90°in...
47
10,916
Hello everyone, I am working on trying to record a history of user logins with a time stamp. It will record their user ID and the time that they...
3,880
