What software s needed to edit a Siemens OP20
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,324
Hi all,
problem is this:
Our man in china has made some changes to an old S5 program, and needs to update the operator panel OP20 accordingly.
But it appears that Protool doesn´t know this type of panel.
What software is needed, and which cable ?
Thanx
Hello Jesper;
The OP20 is an old beast; the only info I have on it comes from a 1996 S5 catalog.
The software used to program it is DOS-based, and is called COM TEXT. It is not available for sale, but some distributors may still have it in their archives, and generally will give it away.
Cable: suggested cable is 6ES5 734-2BD20, but that is for a Siemens PG (programming unit): PG 730, PG750... If your contact in China has one, use that cable; the TTY connector on the PGs provides the 24 V DC for the loop. If not (using a PC ComX), use cable 6ES5 734-1BD20 with an external 24 V supply unit, such as B&B electronic provides (sorry, can't find the exact part no right now, but tech help at B&B can look it up for you).
Hope this helps,
Daniel Chartier
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,620
TSX-P57104 PLC (TSX Premium Telemecanique) What application software is compatible to read the logic existing? Is it Unity Pro or PL7 ? What...
1,808
I am looking for some old software, Logicmaster 90 for GE Fanuc 90-30. Anyone have any ideas where I can get it?
3,152
I'm working with an Electro-Craft DDM-005X drive and I need to plug into it to collect some data. This machine was built by an integrator that no...
4,708
Does anyone know where i can get a copy of AB 6200 software that i can run with dosBox?
2,548
