When copy doesn't copy ...
croakus
May 2004
Dayton, OH
101
All,
I was working on this program this weekend and ran into something 'new' (more like What The He__). I copied a rung from another station and pasted into my logic and found out the COP length of two was only one. See below:
The COP on rung zero was working on the opposite hand machine, but not here. It would load 32767 from N7:22 to N7:20 but not N7:21 ! I finally had to add the MOV on rung two to get it to run.
I'm not using indexed addressing in the program but added a MOV 0 S:24 as a new rung zero. No luck.
The cross reference is the same station to station.
Any ideas?
Mike
Duh
Paul,
Thanks for waking me up. I was thinking in terms of a constant -i.e. COPying a zero to multiple words. Not the fact that I'm referencing a file "#N7:22".
I just didn't remember putting values into both N7:22 and N7:23 on the first station.
Thanks again
Mike
Productivity3000. I have a 32 bit integer, 1d array that i need converted to a string. The string to array seems to work with the same time type...
2,177
Hello I wanted to copy a program. I'm using a MMC slot in my laptop Fujitsu-Siemens. Both MMC Cards are from Siemens orginal. I'm using s7imgrd1...
4,906
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
78
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
88
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
164
