Ronnie Sullivan
As the title; sometimes you don't know whether to laugh or be impressed by the 'out of the box' thinking.
I went to a special brick-making machine that had 2 pots on the panel door to change the timing of how long the mold was vibrated and how long the bricks were tamped.
One timer was erratic and the other pot only worked on high or low.
Inside was an old Mitsubishi FXon plc.
The machine was 30 years old and I suspected the pots had gone dry in that time.
There were no timers in the panel so I wondered how these pots were controlling the time?
I followed the pot wires and they went inside the plc through the side air vents ??
FX plc's have 2 onboard pots to alter values in 2 registers.
I opened the flap they are under - and both were missing.
I went online with the plc and saw the values change and jump about as I turned the panel door pots.
Somebody had desoldered the plc pots and soldered the wires from the door pots in their place.
I replaced the door pots and all was well again but?????
