Which software for S7-300
This is what I am connecting to. I have no idea if this is significant or not. The ESA VT505 (HMI) is the cable entering the PLC at the bottom. Then I am plugging in at the DB9, of course.
Re the photo from the online information, it appears that the version of the programming software is not listed. In the newer S7-1500 you can see the program version - I don't work with TIA software with S7-300 so it was a guess from my side that you could see the program software version.
But I think that the problem is that the program is made with STEP7 classic.
Re the photo of the connector.
It is fine that you connect to the 'piggy-back PG connector'.
In principle the termination switch is in the wrong position. It should be in the ON position for the end of the cable. Same for the connector on the ESA panel (unless the cable continues in a daisy-chain to other devices).
The reason that the ESA panel and the programming software works ok (except for the program version issue) is that the MPI bus on the 312 CPU runs at 187.5 kbps, and at that speed it is quite resilient against wrong cabling. Is that even a proper MPI/Profibus cable ?
Is that even a proper MPI/Profibus cable ?[/QUOTE said:
With my extremely limited knowledge of Siemens PLC', I wouldn't know proper from improper, being completely honest. If you mean my connection cable, that should be correct, I confirmed with Siemens vendor and tech support.
Is there a version of Siemens software that can be used to view only the installed program logic and diagnostic buffer to determine system and bus...
2,107
I have wago 300-316, can anyone help which software and cable can be used to download and upload the program from and to PC. Thanks
1,213
Does anyone know about this RAE300.msi file needed for Studio 5000 to use an Ethernet module in the I/O configuration? I looked and ran the setup...
4,152
Hello! I haven't worked with software redundancy before, so I was wondering if I could use the CP343-1 Lean modules (which I'm using for the...
1,771
I am familiar with the Allen Bradley software required to communicate with the various Allen Bradley PLCs. I have no idea what is required to...
2,804
