Why does Siemens make it complicated
I am glad this site is roaming with knowledgeable people willing to teach like that :)
After using Danfoss drives I had to setup a Siemens inverter using 'Drives ES' and had issues even installing the software from DVD
A Siemens area manager came over to see my issues and helped to get it to work. When i mentioned why does the software consume >1gb of my hard drive and the inverter have >1000 parameters i was told because they design products for 'Engineers'
BornWild > I have been trying to understand the starter software by siemens and I really couldnt understand . Are there any good advanced manuals and how to commission a cpu cu 320 with profinet interface and s120 drives . It is so confusing.
Correct me if I'm wrong . . .
But shouldn't the CPU (PLC?) be set up and programmed by something like Step-7 . . .
And then the S120 Drive(s) get set up with Starter?
Poet.
Poet.
Both would now be covered in one TIA project. An it's become a lot more simplified.
Why they carried on the byte swapping into TIA i don't know. It's a hangover from a real long time ago. Still, if you know it's there, no issue.
Software just depends on the system you are using and how it was originally programmed.
I hope for your sake its a TIA project as everything is more integrated into one system.
If its an older project than you will likely need starter for the drive, and S7 for the controller.
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
809
The picture attached relates to the properties for the F9 key. Does anyone know what 'object number' refers to? What does 'object number' mean...
723
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,734
Hello Everyone If a Siemens PLC does not contain the optional battery or if its battery is discharged, will we lose the program if the super cap...
1,018
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,157
