Why is 1492-ACABLE*YD Needed
Mayaya2017
Nov 2017
Vancouver
We are trying to use 1492-AIFM8S-3 module with 1756-IF8I module.
RA has a technical post "728767 - Wiring system solutions for 1756-IF8I, 1756-IF8IH, 1756-OF8I and 1756-OF8IH IO modules" showing you will need a 1492-ACABLE*YD part number to connect the AIFM8S-3 to IF8I for internal loop powered devices, and a 1492-ACABLE*YA to connect the AIFM8S-3 to IF8I for external powered devices. I.e., according to 728767 you CANNOT mix external powered device with internal loop powered device onto the same IF8I when 1492-AIFM8S-3 is used, you have to assign them to different IF8I modules and use the YD and YA cables accordingly.
I don't understand why that is necessary. In my understanding, external powered and internal powered devices can be mixed on IF8I, either YD or YA can be selected in conjunction with AIFM8S-3. A supporting clue would be page 215 of 1756-UM540E-EN-P, in there the manual shows for IF8I current type of wiring, YA cable is the only option you will need. Compare the 41171-192 and the 41171-199 wiring diagram in the 728767 and draw your own conclusion. (BTW, there is an error on 41171-192, pin 30 and 29 on IF8I are reversed).
There seems to be a discrepancy between the 728767 and the 1756-UM540E-EN-P, doesn't it?
Could any guru explain to me which one of them is more true?
Many thanks in advance.
So we have a panel. It has 1492-h6 fuse holders in the branch circuits. Will my panel have a max SCCR of 10KA? 10KA is the default SCCR value...
1,853
Using a 1762-IQ32T DC Input Card Ser A with a prewired 1492-CAB010U62 cable and I can't find pinout data anywhere. I think it came with the cable...
2,815
Hi! Has anyone got symbols for the AB conversion modules 1492-CM1771-....? These are modules used to convert 1771 series to 1756. Thank you
2,100
Is the connection between 1492 and 1762-IQ32T same as the connection between 1492 and 1746-IB32? As they are from the same manufacturer
2,112
folks, I have a controllogix 1756, DO Card (OW16) connect to 1492-IFM40F-F120-2. I did a test at a pin on 1492-IFM40F-F120-2, Force a bit on, and...
2,820
