I have created a widget with folder binding enabled.
The widget also has an associated action.
The action is : change value, data=tag1 to write to=tag2.
Everything works the way I want it to, however on binding, the action tags do not automatically update.
I see there is an "add action" in the widget parameters.
Trying to figure how to use that.
FWIW the action is added at the tag level and not widget level.
Also this is a "building block" for inclusion in a larger widget.
Is there any other detailed info available other than the user manual which does not have enough detail for what I want to do.
TIA for any help.
TIA for any help.
