Win CC/SQL server error code
SCADA_Dude10
Nov 2011
Colorado
22
Hello all,
I am new to posting so please go easy on me.
I am tring to install WinCC (not flexible) on a Windows 7 Ultimate Version 6.1 SP1 64 bit computer. When the installation gets to the "SQL Standard Database Services", it crashes with "Unknown MSI Error Code:29" I have tried uninstalling and reinstalling all the SQL server components. I have Googled this to death. I spent an hour with Siemens tech support. They said to turn off WinCC Flexibles auto start (among other things). That did not work either.o_O
Thanks in advance for any replies.
Thanks for the response. Unforunately the software installation crashes during installation of the prerequisites and never makes it to the point where it tries to install WinCC V 7.0 SP3. Is there a way to install WinCC before the SQL server?
Thanks in advance.
P.S. I am the local administrator, Thanks
WinCC/SQL error code.
Hello all,
Well I got the problem fixed, with Siemens tech supports help. If you have installed WinCC V11 Portal, and uninstalled it because it didn't work for you (which I did). You can't install the older different version of WinCC without formating your hard disk (at least that was their only solution right now). I used a Linux disk image to bring my laptop back to factory original. Then when I installed WinCC V7.0 SP3 it worked.
Thanks for the replies.
i think this type wincc is not siutable for the w7..install it on winxp professional...it will works..dont forget to install messeing queing
I'm trying to use a copy of my (new) customer's Siemens Step 7 project files to further my knowledge of Step 7. I archived his project files today...
3,127
Dear Friends During the Installation of WinCC v 6.0 there was a requirement for installing SQL server 2000(WinCC instanz) . and I dont know about...
15,548
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
60
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
199
Dear Friends, I have face a lot of problems using Panelview Plus 7 Series B with Win10 IO: I can not map a netwaork drive, when using file...
131
