Hi everybody,
I have a comprehensive S7-400 logic in SCL language and I want to use a soft plc to control a simulated plant with the same logic. In fact, the logic is for a real plant but we are simulating the plant with every possible inputs and outputs in a software which can connect to OPC server. In addition, we want to use soft plc instead of a S7-400.The problem is the software environment to run the logic and connect to the simulated environment. I've searched and found WinAC from SIEMENS as a Soft PLC. Is it good for my purpose? Does anyone has experience with that? Can I transfer my logic to WinAC with less effort? Does exist any other Soft PLC to run SCL language?
