WinAC Soft PLC and Simatic Net
Engineeren
Mar 2004
Ýstanbul
20
Hi All,
I am new for Simatic and i endeavor to communicate my java based application and WinAC Soft PLC for my master thesis...
After i installed WinAC, i do not open because a warning message(which is Simatic Net is also installed on your PC) occurs...
1- Does Simatic Net come with Simatic Manager?
2- Does "Simatic Step 7 v5.3" contain both WinAC Soft PLC and Simatic Net?
Thanks,
Eren
Hi Eren.
Simatic Net is a program that must be purchased separately. It is not included in STEP7.
Same with WinAC.
These are socalled "Runtime softwares".
However, you can do the setting up and programming of a project in STEP7 that contains both Simatic Net and WinAC, without having to purchase Simatic Net or WinAC runtimes.
Try to explain more detailed what the problem is.
Post a screenshot of the error message.
Hi Jesper,
I developed a java based railway signalization simulation project for interlocking systems. For this project, the simulation side is ready but i control signalization via Soft PLC. i endeavor to analyse which programmes i need.
1-WinAC Soft PLC
2-OPC Bridge (if it Can be used for communication between simulation and WinAC)
Is there programme which i need out of these? and How can i use these programmes in order to integrate with my application? i wait for your detailed comments...
Thanks,
Eren
Hi everybody, I have a comprehensive S7-400 logic in SCL language and I want to use a soft plc to control a simulated plant with the same logic...
1,928
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,866
I am developing an application for condition monitoring and trying to sort out the hardware needed; Think about using IPC477D Panel PC but cannot...
2,456
Hello, I have a simatic winac slot cpu 412-2 pci v3.4, the pc is crashed and I want to switch it to new standard pc. My problem is how to put the...
2,032
Hi all Could you upload WinAC ODK 4.2.1 for me, i have found it for a long time. It's so necessary with me. Pls help
1,944
