Wincc 7.4 Redundant server configuration
chapani
Jul 2014
Tax heaven
22
dear all,
i'have set redundant server Wincc SCADA configuration with 4 client applications. redundancy is enabled and is working properly, clients are fully operational, but i have issue to read on client active server name.
internal tag @RM_SERVER_NAME is working on servers runtime, but on clients it doesn't work, on client the field has a mark like when used tag without connection to PLC.
any help would be appreciated!
thanks
Hello, Could you please take a look at the attached scheme in PDF. I'm planning such a single-user redundant system. I can not understand how...
3,133
Hello, The only option for redundant connection from two redundant WinCC PCs to a S7-400H system is industrial Ethernet and Redconnect software...
1,797
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
100
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
109
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
93
