WinCC and Proficy Connection problem
userxyz
May 2002
any
2,768
Hello,
Since this morning I'm having an issue with a connection to a CPU from Proficy and WinCC. The connection is interrupting and connecting continously. This causes a bad visualisation view and unvalid reports.
This is what I see in WinCC
Here I was thinking, maybe the interruption is because of some tags that are reading or writing on unvalid adresses ?
But then I saw this:
So the problem must be a network problem I think ?
In proficy I can see that it's connecting and disconnecting...
I think I need to call the IT dept. to solve this one...
What do you guys think ?
Kind regards,
G
Yeah, if you can ping a device only SOMETIMES, seems pretty likely that's a network problem not an application problem. If you can do a ping test from another PC and see the same issue, then that seems pretty solid that its a problem in the network vs a problem with the networking on the PC.
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
29
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
67
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
68
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
146
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
198
