Wincc auto assigning discrete alarms
dean_ham
Oct 2009
UK
Hi, i am currently having problems with adding a new discrete alarm to a project using wincc flexible advanced.
The project was previously created using protool but our machine manufacturers converted the project over to wincc. Now this is the first time I have had to create an alarm using wincc.
I have written the program in step 7 to bring on the alarm with DB3.DBX312.0 I would like to keep this the same and not change it as our other machine has the same alarm number.
When opening the project up and going to the discrete alarm tab right click and add discrete alarm to the list, wincc automatically generates an alarm number (DB3.DBX322.1) all i want to do is change this alarm number to the one i want (DB3.DBX312.0) But wincc does not give me the option of changing the alarm DBX number.
I have looked on the help file and phoned siemens help line and they explained that i need to create a tag for that. But when i search for that tag i have created i cannot find it. Also none of the other alarms in the list have tags?
Automatically generated alarm number, cannot change....
Cannot select my bit number only 312.0 word....
The tag i have created linking from DB3.DBX312.0 cannot be selected???
Any help would be much appreciated.
Thank you
Dean
Is the DB3.DBX312.0 a seperate bit in that DB or a part of a BYTE/WORD/DWORD?
You can't select a seperate bit if its a part of a BYTE/WORD/DWORD. In this case you need to make a Tag of the BYTE/WORD/DWORD and then select the bit (bit 1) in the Discrete Alarm options.
Hi All Do you know if there is a way to change the process screens automatically (e.g per 10sec.) in wincc v11? Thanks
1,518
dear friends i generate a reoprt in wincc now i want to auto email to selected address any body who can help me i want to save this report in...
1,865
Hi all. Just wondering is it possible to set up a predictive auto go too of saved recipes from a recipe view window. I have a customer who has...
4,248
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
45
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
