Wincc dump to CSV/Excel sheet
ZAMA22
Feb 2015
Midrand
Hi guys, I'm currently busy with a Wincc project which requires me to dump field data and physical inputs entered by an operator on a Wincc scada to a csv file for reporting purposes. Now this is my first time working with wincc and i just want to know how i can go about doing this??? i understand that some form of scripting may be required and to be honest i kinda suck donkey nuts when it comes to scripting!!! but either way I'm willing to learn:oops: Any tips or pointers???
Thanks in advance
In WinCC,Scripting is available in "C" and VBS
Sounds like you're going to end up doing some scripting. I haven't written CSV files but I've done TXT files a few times and CSV is only formatted text. I'm guessing you willneed to build an array of strings, where each string represents one line, and write it out to a file.
With a CSV file, each line should contain the required numnber of separators even if there is no data.
Maybe someone could offer a better solution?
Nick
Maybe this can be of help! With these advices from the thread I posted I created a VB script that logged the values I choosed. I could even name the .csv file from the PLC and it will create the file if it doesn't exist and if it does it will add.
Read through the script and you will understand it, it's actually pretty simple when you get to "know" it!
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
65
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
146
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
198
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
