WinCC Flex 2008 USB driver for Windows 10
Jun 2020
London
20
I have WinCC Felxible 2008 SP5 installed on my Windows 10.
I want to program Simatic panel TP177B using USB transfer cable.
But i can't find any USB device drivers for Windows 10.(Please refer pic)
Can anyone please tell me where can i get it?
Thank you
Regards
Liston
Thank you
Regards
Liston
Not to be flippant, but asking Siemens tech support would probably be a safe place to start.
Do you mean to use a regular USB-to-serial, or the Siemens PC Adapter USB ?
The 1st one isnt possible with the TP177B.
The 2nd one should be possible to select if you open the PG/PC Interface, and select S7ONLINE = PC Adapter, and then in the settings for the adapter specify USB.
edit: Do you have both STEP7 and WinCC Flexible, or only WinCC Flexible ?
If you have STEP7 then the latest drivers incl. the one for the PC Adapter USB will already be installed. Not sure when you only have WinCC Flexible. Maybe, maybe not.
edit again: It just dawned on me that maybe you want to attach the TP177B as a USB device on your PC. I am not sure if that is even possible.
In case of PC Adapter USB, then maybe your problem is that the driver for Windows 10 comes with STEP7 V5.6 or TIA V13 or greater. If you dont have these, you could install a trial of STEP7 V5.6 or TIA V16.
Ah, I saw your last post. So it is a generic USB Host-to-host cable.
Hmmm. dont know about that.
I think that maybe the TP177B manual tells you which USB host-to-host cables are compatible.
What is the exact type no of the TP177B panel ?
edit: i think this was possible with some panels, but only with a few cables that where tested and found to work.
USB host-to-host is not a standard. The cable you have is for PC to PC connections and almost certainly require that a specfic driver is installed at both ends.
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,682
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,788
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,244
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,425
I'm going through another torture test exercise of working with outdated hardware and software and have hit a brick wall. The HMI is a MP-177...
1,843
