Runtime with MPI in Wincc Flex 2008 SP3
swedeleaner
Dec 2013
Göteborg
143
Hello!
Another weird request from the swede with customers that doesn´t like to pay for quality in first place...
Is there any way to have a functional runtime on a PC with a MPI-connection to the PLC?
My customer claims that the former german programer (Those weird german professors, they will give me a heart attack some day) somehow controlled the HMI (or just ran a runtime) from his computer using the MPI-interface. :mad:
is this even possible?
Maybe my customer saw a simulation runtime?
The project is created in WinCC Flexible Advanced 2008 SP3.
Ohh! cool!
Do you mean the usual USB-MPI adapter (Black & green)?
I think the customer already own one of these.
Otherwise, i can try this with our CP-5711.
What do i need to do besides this?
A runtime-license or how do I get connected?
Or will it work just using the button "Start Runtime"?
Ohh! cool!
Start runtime will do!
No license needed to start. It will however complain about the license but you will still have full functionality
You do need WinCC flexible RT (Runtime) installed on your machine it is on the same DVD and you get an option to install it when you install regular WinCC Flexible.
Nope not me different guy different town.
If you have started runtime once you can look inside the S7 project folder and inside the HMIEs folder there in the project folder you will have a *.fwx if you double click that runtime will start directly. Great for troubleshooting especially if the machine is connected to wifi.
For WinCC Flexible RT to be able to go online with the PC Adapter USB, WinCC Flexible must NOT be part of a PC Station. Just plain simple WinCC Flexible RT on its own.
In the connection setup in WinCC Flexible, the connection must be defined via S7ONLINE, not "softbus". If you see S7ONLINE and it is set to the correct MPI parameters, then it will work.
Greeeeaaat!
Thanks again guys for saving my day!
I instructed the customer with the steps you described and it works perfectly now! You rock! 🍺
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
when i tried to go online, why its showing lie this
92
I have been trying to add a button to an HMI Panelview version 5.1 for a couple days. Each time I download I get no data in my buttons, only...
210
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
691
Hello ladies and gents I’ve hit a road block on a project, it’s AB for preface this is a converting line including Winder tailsealer and...
778
