WinCC Flex Data Logging
Jack Schit
Oct 2009
England
35
Hi All,
I am using WinCC Flex 2008 to log tag values to excel in CSV format. However, if I log more than one tag to the same file, the different tags are logged in the same column in the excel sheet making it difficult to analyse the data.
Is it possible to modify the CSV format so that each tag has its own column in the excel sheet?
The native data logging in WinCC Flex does not allow this.
I think that with a bit of effort you can get the data sorted nicely in Excel. I think a pivot-table can do the trick.
Apart from that, I make my own CSV data logging via VBS for exactly this reason. Search for "WinCC Flexible CSV"
Thanks Jesper,
I have virtually no knowledge of VBS so will stick to manipulating the numbers in Excel.
I have tried to delete the duplicate thread but seem to be unable to find the function!
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,434
PLC: S7-300 HMI: Siemens TP177B I would like to limit data records in a recipe (WinCC Flexible Advanced). I don't want the user to save more than...
1,556
Hello, I have a problem with data logging in wincc flex. I want to log an entire DB (+/- 50 Real's) in a .csv file. So i've created a tag of...
2,528
Hi I have a faceplate where the user has to enter a time, in seconds. This raw entry is milliseconds and usually i would use the tag settings to...
2,989
Hello Friends ! Using siemens wincc flex and lgging the historical data on MP277. Need to view all the data on remote PC which is on ethernet. How...
4,890
