cotang Member C Join Date Aug 2006 Location calgary Posts 58 Nov 12, 2008 #1 Is it possible to change the Tag to reflect a different tag during runtime? Ie. Tag is looking at DB1. Click a button Same tag now looks at DB2. Thanks.
CharlesM Member C Join Date Aug 2005 Location Arkansas Posts 1,129 Nov 12, 2008 #2 Maybe You can have a multiplexed tag. Where you have an index variable that will move the tag up and down a DB. So you could move a tag from DB1.DBW0 to DB1.DBW2 I don't know if you could go between different DB's. You can find an example here http://www.plctalk.net/qanda/showthread.php?t=40785
