Wincc flexible 2008 - Array syntax in script
naturephoenix
Jan 2015
Vienn
181
I have 4 arrays.
1. -> arrdb1 (array of 52 bytes)
2. -> arrdb2 (array of 20 bytes)
3. -> arr1db300 (array of 20 bytes)
4. -> arr2db300 (array of 52 bytes)
I need to copy arrdb2 in arr1db300 and arrdb1 to arr2db300
in for loop, but i dnt know the syntax
my try:
Dim i
For i = 0 To 20
SmartTags("arrd1b300")(i) = SmartTags("arrdb2")(i)
i = i+ 1
Next
But this is not working
Hi have you considered using the PLC to do this? use SFC20 and call it with a bool tag from the HMI
I can't find the reference right now, but I think I read once that referencing arrays in scripts didn't work the way I expected them to.
Have you tried copying the whole array at once (arr1 = arr2)?
I may be wrong but normally in a for next loop the index variable is incremented automatically by the "next" statement. Try commenting out the line i=i+1 and see if that works.
One more thing, 20 bytes would be 0 to 19 and not 0 to 20.
Nick
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
271
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
112
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,481
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,288
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,853
