WinCC Flexible 2008 faceplate String
enault
Jun 2008
house
35
Im creating a faceplate that will be used to show Each Input. the name of the Input will be located in the S7 plc. i need to show in the faceplate Both the Full name and in an other IO field, only the 2 first caracter of that same name.
When i put the String Field Length to Only 2 the IO Field would only Show "##" because the string is actually longer than the field
i Would like to fix this without adding 1 more tag in the PLC for each Input because ill be a bit short on the number of tag.
i could easily extract those 2 caracter with a script but it seems that there no such event as Loading or activate in the faceplate. That must be done without having to click a button or do any action .
i Had try to add a string Property in the faceplate and link it to a HMI string Tag, but im still wondering if there a way to set a default value to a WinCC Flex Tag (remember that i dont want to add more tag from the PLC, too close to tag limit) Do i need to use a script that would set that tag each time the HMI start?
so if you have any idea how i should be showing those 2 first characher of a longer string in my faceplate, Ill be happy to read It
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
271
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,481
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,288
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,854
