wincc flexible 2008 not open
eng_ali_abdo
Feb 2013
egypt
i have abroblem with my wincc 2008 flexible when start it on a simatic manger it give me not able to connect to the sql server and make the program stopped i had try to install but the same problem
I had a couple of problems with Win CC, missing a template.tmp file someone zipped & sent me, then wouldn't open.
Ended up completely uninstalling Win CC AND Automation License Manager (with deleting all files & settings when prompted) & then doing a complete reinstall - tried repairing the install & modifying it but no change. After that it works OK, just remember to check your license after you close Win CC because on mine it sometimes still shows the lis'c as USED & I have to reopen Win CC, reopen a project, close the project & close Win CC - then the lis'c checks OK.
My issue wasn't a license problem either - it was first missing a template file which repair & modify never reinstalled & then it popped up an error showing SQL & then closed - I simply added the license check as a forewarning.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
292
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
114
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,484
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,309
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,861
