WinCC Flexible 2008: Run Script when screen is open
STL???
Sep 2005
UK
879
Is it possible to have a background script running behind when a settings/log screen is triggered?
I know i can run a script on Screen load/Unload within the properties of the screen and i'm aware of the scheduler,however i dont see an option available to suit my needs.
I think you need to elaborate a bit on your specific needs.
All I know is one can run scripts on load and clear, which is insufficient in this case it seems.
Hi Jeebs,
One of the first problems i'm having is that i cannot find a way to automatically update an I/O field with a logged in user.
e.g
i have a button to login a user and an I/O field to display currently active user, i cannot find a way to update this I/O field without a second button to utilise GetUserName to move the string to a tag, i want it to work from the login button because the user string is important - what if they forget to update?
I was thinking of utilising GetUserName inside a script to update a tag which is referenced via the I/O Field.
GetUserName SmartTags("dbEMS.UserID")
hope this makes sense
No need for script, this can be done within the Scheduler:
Event: Change user
First action: Traceuserchange
Second action: Getusername
This one will output it into a tag, we use an internal tag.
Below is how we do it:
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
294
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
116
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,486
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,313
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,865
