WinCC flexible 2008 Standard installation problems
Feb 2013
Chorley
I am currently trying to install WinCC Flexible 2008 Standard on a windows 7 32-bit machine. In theory this should be straight forward however the installation stops when installing SQL server 2005 express. The following error message is generated:
The following program could not be installed:
Microsoft SQL server Express Edition SP4
Setup cannot complete the installation.
148
Unknown MSI Error Code: 148
Any suggestions on what I need to do install this software will be gratefully appreciated.
Cheers
Shane
I have tried 1.4 of the section that you posted as this seems to be the only section that is applicable to my issue, but the same error occurs. Do you have any more ideas?
Did the deinastallation of the various MSSQL components go through ? Or did it fail for some reason ?
What other programs are on the PC that could be using MSSQL ?
I have a number of rockwell devices using SQL 2008 R2.
MSSQL Server 2008 R2, doesn't appear to uninstall I get a message that a WMI has failed (see attached).
It does not provide anymore deatils.
So the Rockwell software use MSSQL 2008, and WinCC Flexible uses MSSQL 2005.
Maybe try to deinstall all Rockwell Software (!), then install WinCC Flexible and only then install the Rockwell Software.
RA FactoryTalk View Studio 6.1 is running "on-top" of the MSSQL 2008!
I don't know what to tell you...I heve personally learned (the hard way of course!) to keep Siemens Software as "far away" as possible from any Rockwell Automation stuff, especially FTVS.
You might need to try running one or several VMs (VMware would be my brand choice) and segregate the software families.
Unfortunately, I see you have a 32-bit machine...:mad:
I wouldn't attempt running VMs on 32-bit Host OSs; 64-bit and at least 8GB of RAM would be my "mimimum".
i run both on the same computer but under xp...Siemens soft was installed first then RS+FT and the only thing is to manage with RSlynx and siemens driver trying to use same ports.
I made a CCcleaning and had to re-install some SQL package for wincc and tia but when you pass thru installation, it works fine.
I just have to shutdown rslynx when using Siemens and it take control back when using RS again
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
274
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,481
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,292
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,855
