WinCC flexible 2008
exmore84
Feb 2011
Diest
Dear forum members
I've got a question about wincc flexible 2008. A costumer of our company want's to see the alarm window outside wincc. Why?
On the panel or two program's running, wincc and some camera program. Now if the costumer is busy in the camera program and there is a alarm he see's now a alarm indication but is it possible to see the alarm window outside wincc? Now the alarm window is only to see inside winCC. Is it possible with a scrip or something else? I hope someone can help me.
Grtzz
Frederik
If the issue is the need to run multiple programs on same pc as the runtime the answer is to use 2 monitors and extend the desktop so that the runtime sits on its own monitor so that it is always available and other tasks can be done on the other monitor.
Oké i know what you mean, but then is there still the same problem. They must switch between screens.
Hi Use the template alarm window then it will be visible on every page of wincc on the extended desktop.
Also maybe your customer is expecting too much it is like using your tv for watching a film then missing your football team scoring a goal.
There maybe a way using scripts of running wincc in the background and then maximising and bringing to the front but in my opinion why have a HMI if they are not going to use it.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
279
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,481
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,292
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,855
