WinCC flexible connections
JasonWade
Oct 2005
Preston
160
I am having problems adding a new STATION in to my WinCC connections. I want to have both PLC's talking to the HMI via ethernet.
I have the following items all connected by ethernet;
317T-DP processor with CP343-1 Lean
317-DP processor with CP343-1 Lean
MP270 touchscreen
Simatic manager shows that all the items are connected, however when I try to add a station the 317T does not appear in the drop down list.
What am I doing wrong?
Thanks in advance
Try to setup a similar project with 2 x 317 (no 317T).
If this goes OK, then it does look there is some incompatibility with WinCC Flex an the T CPUs.
If it does not go OK, then there is something wrong with your installation. I have just made a test and it went OK.
I cannot test a 317T myself as I dont have the option software for that.
Hi Jesper,
I don't have the Technology option installed, I think this is the problem.
WinCC shows the 317T connection when it first starts up, then it disappears after an automatic S7 synchronisation.
I will have to get S7 Technology, do you know if this is available as a working demo or trial version?
If you dont have the technology option, then there will be a big fat yellow question mark in the Hardware Configuration for the 317T.
I dont know if the S7 technology is available as a demo.
You can try to setup a non-integrated connection from the HMI to the 317T.
I presume that your wincc flex is integrated in the your project .What you could do is to use it as stand alone and then try and add another connection.
Eric
Hi all, I have 9 PLCs s7-1200, all in switched ethernet network, to connect with wincc flexible 2008 RT As i remember, that i read somewhere...
6,847
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
369
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
125
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
774
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,633
