WinCC Flexible negative(-) number problem
necyil
Nov 2004
Turkey
102
Hello All
On the plc (s7-315dp) actuel value db11.dbw30 is -200.But i cant see that value on the wincc flex.(i see like that #####)
Also set value db40.dbw30 between -300, +500.
My probem is how i send and reda negative value on my winncc project.
Pls help me
best regards
Necyil
Not sure what goes wrong with your project.
If the tag contains a negative value, I get a "-" sign in the display.
The output field is formatted as 999999 in my project.
Maybe you have reserved too few characters. The "-" sign takes up one character, as does the decimal point.
Dear JesperMP
Many thanks for yoyr fast replay.
I made output format 999999.
Now i see on plc -270.On wincc 65266.
How i solve?
best regards
necyil
Hi necyil.
It does look like it is displayed as an unsigned INT. Only problem is that neither S7 nor Flexible has this kind of variable. Maybe something is formatted as DINT by mistake.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
271
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
759
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,586
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,481
