WinCC Flexible Recipe
CharlesM
Aug 2005
Arkansas
1,129
I have a customer wanting to search for a part number (record name) for a recipe in WinCC Flex. I have a recipe screen setup with an advanced recipe object. This has a drop down box that list all the record names in order. I would like to add a search button so they can enter part or all of the number and pull up a list of all that are close to what was entered. I don't see any easy way to do this. I may be able to write a script that will do it but im not sure. Anyone have any ideas?
I found this old post while searching for something else. I did come up with a script to search recipes. I run a loop and read in all the names in the recipe. Then I search the names to find matches. Then I post the first 10 that match the search text.
If anyone would like to see it I can post some screen shots and some code.
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc flexible runtime PC i use the recipes as...
7,029
Hi all Can anyone help me how can disable box of recipe to ask save pls look at picture attach. I dont want it appear and dont want it auto save...
1,846
Hello, I'm using recipe to save some cycle time information for a production line. Everithing works goods,i can save the recipe and all my...
1,867
Hi guys, I need a solution about recipes in Wincc Flexible. For the purpose of automatic production sequence, I want the transition of data...
2,145
Hi All, I am currently programming WinCC Flex Advanced for a PC that I will be putting on a runtime license. This willl be recipe based and I...
2,618
