Hello,
I am using WinCC Flexible and want to test a script with the runtime simulator. Does anyone know if the scripts will run in the simulation mode? I made a simple IF, THEN script and some internal tags but the values on the simulator screen do not change. I can enter the values into the fields and they show up but if the script tries to change the values, they do not ever work. Basically I am using the statement IF tagname = 1 Then setbit tagname.
Thanks,
Pete
Thanks,
Pete
