WinCC Flexible Tag Number Display
Hayzed1
Oct 2005
Ontario
19
Hello everybody, I am working with a (relatively) new software package, WinCC Flexible 2005 (Replacement HMI Software for ProTool).
I am pulling a tag from a 315-2DP Siemens PLC, which is a Real number displaying the weight.
The number formats in the WinCC Flexible only shows a "999999" format, but I would like to have a comma when the "thousands" are finished (i.e. 99,999 or 9,999). I can't seem to get this to work.
Has anyone had experience with this? I am pulling from an MD if that helps.
Thanks in advance,
Hayzed1
I know you can do decimal places but I don't see any way for ,s. If all else fails you could call a script on change and insert the ,s and return it as a string for display. If you come up with another way please post it.
Hi.
All you have to do is to write what format you want. So if you want a number to have the following format 785.78, you just write in the I/O Fields format property 'Format pattern' 999.99. Hope this helps you.
/Stefan
No, it is not the decimal point that Hayzed1 is talking about (I thought too at first).
He wants to display values like this:
23
456
7,890
12,345
678,901
2,345,678
etc.
sounds like a job for a script called on change of value...
convert int to string and use mid function to group into groups of 3 then add comma's
Resurrected thread warning !
Anyway, I dont think the splitting of the value into thousands with commas is reason enough to write a script. To my opinion scripts shall be avoided unless there is a very good reason.
oops....
Why do people restart old threads? Surely search for your answer then create new thread if required...
Jesper .... I agree with whatyou say about scripts but sometimes the customer is a pain and wants stuff like he is asking for
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,397
Dear all, I nead some experienced situation answer :) I have wincc flexible rt connected to plc db in plc looks like this: db100.dbx0.0 - one...
1,790
I am trying to find out if there is a way to "read" the tag comments in WinCC Flex 2008 (SP3) during runtime. I'm using WinCC Runtime on normal...
3,864
hello. How can i know that each "tag" has been used in which screen in a wincc flexible project? best regards.
3,550
Hi everyone, I'm writing an application for a machine that is supposed to run different auto programs, each consisting of up to 50 steps. Each...
5,327
