Wincc install issue
Steve Bailey
Apr 2002
The boondocks of Western Massachusetts USA
8,599
Trying to install WINCC flex but I get this error message. It looks like its telling me the choices for the OS I need to be using include what I'm running. What's going on?
I'm trying to install to a VMware image. Does that have anything to do with it?
Not sure if this applies, but found it some time ago on a forum when I hit problems with WinCC install...
Maybe a little bit late, but today I'd made the change (for the fourth time) from XPSP3 to Win7. The new Simatic Manager 5.5 was installed without a problem. WinCC flex 2008 I made some changes in the configuration.
First of all you have to right click on the setup.exe in the root folder and go to "properties". At the "compatibility" tab you set the modus to Windows XP SP3 and close by clicking OK.
The first problem during installation was the Windows installer 3.1 error, because Win7 uses 5.0. This I solved by going to /CD_1/MSI and opened the MSIInstallerW.ssf in Notepad.
By default, the "isCriticalComponent" value is set to 1. Change this one to 0, save and start the setup.exe in the root folder. Now you will see that the Windows Installer is skipped and all the rest will be installed normally.
You can choose to install all applications separately, but I needed to run the complete WinCC Flex 2008 installation to let run WINCCSQL stuff properly.
Upgrading afterwards to SP2......no problemo.
I hope this will work for those people who still have sleepless night to get WinCC Flex 2008 running in Windows 7.
Regards,
Rob
I have installed WinCC v7.5.0.0 and it was successful with no errors at all. Unfortunately, the WinCC project that I need to open has been created...
1,031
I am trying to get a tia portal v11 application to run and the software is telling me to install wincc basic v11 update 2 and wincc comfort v11...
4,111
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,865
Siemens has recently released update 4 for WinCC Flexible 2008 SP3. On SPS-Forum, several members have experienced severe problems with this update.
10,079
Can anyone help me with this error I have tryed multiple things as removing all siemens software and installing it again. Still not fixed, i am...
1,583
