WinCC issues
Tomo453
Mar 2018
Mt. Juliet, TN
83
I recently encountered screen glitches and subsequent manual controls issues on an automated blanking line. The CPU is a Siemens s7-300 and the HMI is a PC running WinCC RT v7.2. I have posted pictures here. I have had some experience with the exclamation points in that I/O feedback did not match the field conditions. In this instance, I can find no discrepancies. The "Operator Enable at P2" will toggle between high (green) and low (red) and the exclamation points will come and go as well. When I monitor the function that controls the Operator Station Enable (there are three HMIs that access these controls) online with Simatic Step 7, there are no bits changing and the station enabled will be correct in all instances. There are multiple manual controls for separate devices and this is the only entity displaying this condition. Can someone explain the exclamation points and the small icon on the "Safety OK" and the "Enable - no external fault" conditions? I am fairly green with this WinCC stuff.
WinCC_issue_92719.JPG WinCC_issueb_92719.JPG WinCC_issuec_92719.JPG WinCC_issueD_92719.JPG
There is a WinCC integrated function to show when the variable status goes bad with the exclamation mark and do this style of underlying grey behind an animated output.
If this is not a custom function, then the variable status goes bad if the conection to the plc is lost (e.g. network problems) or wasn't started yet, or the variable read request was not successfully answered by the plc (e.g. desired address not available, which could here not the problem as the status ok comes back).
You should take a look into the WinCC logfiles in the diagnose directory of the WinCC installation directory. Interesting is here especially the logfile of the S7 channel.
Hi, I started working with Unified panels and am experiencing trouble with recipes (or to be correct parameter sets). I did check all the YouTube...
811
Hey guys, So I'm adding a new HMI alarm and so I had to update alarm text in winCC. I compiled and went to download and get an error for...
1,619
At the end of the day today I did my first program edit in my customer's Simatic Manager project. It was the simplest of edits... add a bit with a...
2,339
Hello all, When I attempt to start Wincc it always stops when trying to start the user arcive server (at about 76%). If I uncheck user archives...
2,979
I was wondering if anyone else has alot of issues with there installs of WinCC Flex. Anytime I install it, it never works correctly. I have to...
11,501
