WINCC Liscense
Usama_maqsod
May 2016
Lahore
29
I have build my project in WINCC 7.3 and now have purchased WINCC V 14 Runtime liscense in USB Dongle form.Can WINCC advanced Runtime Version 14 liscense will be valid for WINCC 7.3.Please help.
Thank You
Thank You Jesper for Your reply.I am now thinking about migrating my project from WINCC 7.3 to WINCC 14.But have below mentioned confusion:
1. Is it possible to migrate my Project from WINCC 7.3 to WINCC 14?
Kindly help!!!
Yes it is possible, with the TIA Portal Migration Tool.
Try installing the migration tool from your installation source... I think V14 without SP1, you can migrate from V7.3 directly. When I tried with V14 SP1, it told me to upgrade my V7.3 project to V7.4 Upd3 or later.
V14 Professional
I think OP would need to upgrade his license to WinCC Professional. I don't think he would be able to convert a WinCC 7.3 or 7.4 project to WinCC Advanced.
Best regards,
Thank you very much sigmadelta and kelkoon for you support.I have returned my liscense and now purchasing WINCC 7.3 liscense the exact one which is installed to avoid any confusions.
Thank You Again
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
69
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
85
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
81
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
161
