WinCC Powertags - Runtime License
johnyu
Aug 2006
Melbourne
I need to work out the Runtime License for a WinCC 2008 Flexible project. How do I know how many powertags I have?
If I goto the tags tree menu on the left, I see a count of 423 tags, is this the same as powertags? If not, how do you determine the powertag count?
John
Output
When you compile, then view the Output screen. After compiling it will say how many powertags you have used.
regards,
Gerry
John
I finally found it, maybe my version of wincc is different, it's not in the output view.
For anyone's interested, compile the project, right click on the device, then select object properties, power tags is displayed in the general tab.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
68
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
85
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
80
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
160
