WinCC Scripts Text Export
computerdummy
Jun 2012
Birmingham
Hi Everyone,
One of the projects we have has a very large number of scripts that require translating. It would be great if we could export the scripts to text files and make searching much easier.
Does anybody know of a way to do this?
Andy
Are you sure the scripts are not already saved in text format somewhere in the project path?
The file name(s) might not end with the .txt extension and still be in text format.
Just a guess.
Hi Mark, thanks for the reply.
I did consider this but I don't believe it does. There aren't too many files, and none look like they contain the scripts.
In my WinCC Explorer i have a module called Text Library where the translations are handled. There you can export/import as csv or txt files.
hello, i need these files down here, DBExt-DLL (realizes database connections of WinCC-Skripting) MessageStatistic-DLL (status message...
1,019
Hey guys, I am trying to write a vb script in wincc 2007 flexible. Basically I need to have a button which is on my overview on every screen...
1,618
Hello, I am using WinCC Flexible and want to test a script with the runtime simulator. Does anyone know if the scripts will run in the...
8,738
Hi, I hope someone can help me with this. I have managed, using scripts, to export data in a .csv file. The problem I have is that when I open...
2,471
Hello everyone Anybody knows how to access password-protected scripts with the Global Script Editor in WinCC v7.0? 👨🏻‍🏫
3,586
