WinCC, TCP/IP and some other S7 Q
Jeebs
Feb 2007
Leuven
1,059
We are starting on a new project. WinCC6.2 project with some nice added features to make the operators life just that little bit easier.
One of the things we wanted to do was:
Using WinCC to send a string to another PC on the network using TCP/IP. All it needs to do is send said string to 192.168.10.25:37 for example.
A program on this other PC will monitor that port and once the string is detected/received it'll do whatever it does with it.
Is this possible using WinCC?
If so, can someone point me in the right direction?
And thats not all.
Wanted to know if it was possible to see within the PLC-code itself how many connections are currently active.
There are PC apps reading out data from the PLC's (S7-400's) and we'd like to know just how many connections are being used at any given time. this done within the PLC.
Is that possible?
If so, can anyone point that compass in the correct direction?
And thats about it for the moment.
Thnx
Jeebs
And thats not all.
Is that possible?
Thnx
Jeebs
If you have online connection to the PLC you just right click the blocks folder and choose module information under the tab "Communication" you can see the number of reserved connections and the number of connections currently in use. You can also go to the special diagnostics tab under module information for each CP-card and get more information
Dont know about Wincc but if you have an ethernet card in the plc its fairly simple to use AG_send and send a string to a remote partner.
its possible, we do this to control camera's.
I will have to look up the vb code. if I remember correctly we use an external dll to do this.
will post here again next week when I am back in the office.
Regards,
Marsupilami
Hello to everyone, I need to comunicate With a Modbus gateway(TCP-RTU)connected throught Modbus TCP/Ip on wincc v7.5 or professional; i will...
268
We inherited a WinCC system which comprises a ST7 driver. However a near station we have connected to it over fiber optic therefore we have direct...
2,396
Setup: I have WinCC V7.0+SP3 workstation that is going to interface with S7(CPU 315-2PN/DP) (Ethernet TCP/IP) and 2 Eurotherm Temperature...
7,915
Hi all, We just installed an INAT TCP/IP module in our S5 135U PLC rack but can't get it to communicate with WINCC. I checked the manual and...
4,412
Hi, Im trying to connect S5 135U (928B) and CP 1430 tcp/ip with WinCC 6.0 using cp1512. I follow the manual that i attached in this mail. but...
1,654
