Hello, I need help on changing tags inside an object. I have an object that uses the visibility and appearances under animations. An external tag from the PLC drives the visibility and appearance. I need a way to easily change the tags within the object as I have to do so for 190 tags using the same faceplate. Is there any way to do it without multiplexing? Thanks.
