WinCC pro TIA Portal V11/12 Client Server Issue
wazzajnr
Aug 2009
Chorley
40
We have a setup with a Siemens IPC547D as the server and 2 clients, also IPC547D's.
We had these set up at Siemens Manchester on a local network with fixed IP and the dummy project worked just fine.
Now we are on site, on the customers network and although we can see the server from the clients in simatic shell and we can point autostart at the project file on the server, we keep getting "Server not available" whenever we try to log in.
We have fixed IP addresses for all 3 PC's and the RT on the server works fine, it's just the clients we can't get working.
Any suggestions???
Thanks in advance.
Paul.
Hi wazzajnr
I am also having a similar problem at a customer here in South Africa.
We are not using IPC's, but instead regular PC's and a server within a domain. The client can see the server but when a password is entered, the "server not available" error pops up.
Have you checked user permissions and made sure your user belongs to the MSSQL group for WinCC?
Is it possible to convert the project in Wincc Professional to Wincc advance?
1,798
I'm little stucked and ask for small help from one with little more experience of vb script. So, I have alarm control window Control1[Alarm...
1,547
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,029
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,572
Hello all, I have a WinCC Project (Pro V16) connected to Information server 2014 SP3. Everything is configured and works as intended using the...
1,491
