Wincc rt pro to s7 1500 connection
the18
Nov 2019
Casablanca
18
Hello,
I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller.
using profinet to connect all 3:
  • S7-1511 has an IP address of 192.168.1.91.
    IO Controller has an IP address of 192.168.1.11.
    Wincc RT Professional has an IP address of 192.168.1.103
The PG/PC interface is set to S7 ONLINE.
The HMI_connection in Tia portal for wincc rt pro -> S7 1500 is set to CP TCPIP.
The wincc SQL in services.exe in running.
The Computer name isn't changed.
The connection between S7-1511 and the IO Controller is OKAY.
When i ping my PLC using CMD "ping 192.168.1.91" I get 4 responses.
Yet when i run the Wincc RT Pro, it doesn't detect a server so it creates a localhost and when i open WINCCexplorer my project only contain COMPUTER AND TAG MANAGEMENT, no GRAPHICs DESIGNER......
Can someone please help me out. I will add pictures in a pdf file to help with the idea.
Thank you for your time and help.
  • Topic.pdf
I dont have experience with WinCC Pro.
Bit I can guess a few things.
1. On the WinCC Pro PC, you have to set the access point CP-TCP, not S7ONLINE. There is a switch "set automatically" so maybe it is not important.
2. The error message says you have connected the cable to the wrong port. You have configured topology, so the real cabling and port usage must match the configured topology perfectly.
Hello Sir,
Thank you for your reply.
For your ideas:
1. In the pg/pc interface i couldn't find cp tcpip
2. And for the connection to the port i tried changing the port but then i lost connection to the wago io controller too which let me assume that the port is correct, and with that port i can load and connect to the plc using tia with no problem. :(.
Is it possible to convert the project in Wincc Professional to Wincc advance?
1,799
I'm little stucked and ask for small help from one with little more experience of vb script. So, I have alarm control window Control1[Alarm...
1,547
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,572
Hello all, I have a WinCC Project (Pro V16) connected to Information server 2014 SP3. Everything is configured and works as intended using the...
1,491
I am doing something no one else has ever done.... I want a screen that lists all the faults that have occurred in the resent past on one screen...
6,603
