WinCC Pro V16 & Information server report
grnick50
Nov 2010
Ptolemaida
332
Hello all,
I have a WinCC Project (Pro V16) connected to Information server 2014 SP3. Everything is configured and works as intended using the report templates that come with IS. I also went through this manual about custom reports:
https://support.industry.siemens.co...he-wincc-and-pcs-7-environment?dti=0&lc=en-PE
What I want to do is a daily/monthly report of the working hours of a piece of equipment and a report of the kWh produced by a CHP unit per day/month etc. I believe it shouldn't be a big deal if you know IS well, which I don't.
Can anyone give some pointers or directions regarding custom reports?
Note that I can understand SQL and used it before, but it isn't the area of my expertise.
Thank you.
Is it possible to convert the project in Wincc Professional to Wincc advance?
1,801
I'm little stucked and ask for small help from one with little more experience of vb script. So, I have alarm control window Control1[Alarm...
1,557
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,036
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,585
I am doing something no one else has ever done.... I want a screen that lists all the faults that have occurred in the resent past on one screen...
6,612
