WinCC Pro - msgFilterSQL
Weo
Feb 2006
Sweden
82
I'm little stucked and ask for small help from one with little more experience of vb script.
So, I have alarm control window Control1[Alarm control] which I need to filter when the screen is loaded. The filter is not constant but indirect (tagprefix).
As you see I added msgbox in end, and can confirm that the tagprefix is correct.
My script is like this today, but is not working:
(The script does work when I add my actual tagprefix as a constant i.e M1)
Guess there should be some wildcard around my prefix and I'm pretty close?
Sub OnGenerateScreen()
Dim prefix
prefix = Parent.Parent.Parent.TagPrefix
ScreenItems("Control1").MsgFilterSQL = "TEXT3 LIKE 'prefix' "
MsgBox prefix
End Sub
The wildcard for some SQL versions is the percent symbol (%).
So [WHERE ]
Code:
TEXT3 LIKE 'prefix%'
would select records where the TEXT3 character field started with the string "prefix" e.g. TEXT3="prefix"; TEXT3="prefixXIFERP"; TEXT3="prefix_whatever"; etc.
I think you just have to insert the string value of prefix, like:
ScreenItems("Control1").MsgFilterSQL = "TEXT3 LIKE '" & prefix & "'"
Maybe you have to escape the single quotes in VBscript.
I think that it would be simply on vbs code
ScreenItems("Control1").MsgFilterSQL = "TEXT3 LIKE" & prefix
as your prefix is variable and you read it's data and add it to constant string.
Is it possible to convert the project in Wincc Professional to Wincc advance?
1,800
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,032
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,575
Hello all, I have a WinCC Project (Pro V16) connected to Information server 2014 SP3. Everything is configured and works as intended using the...
1,491
I am doing something no one else has ever done.... I want a screen that lists all the faults that have occurred in the resent past on one screen...
6,604
