WinCC V7.3 Script Server crash
Traloch
Feb 2013
Stuttgart
29
I'm having an issue with my WinCC V7.3 project, where the script server is constantly crashing when opening a new picture window and closing the open picture window.
On my root screen (Overview) I have Navigation buttons to open Picture Windows within the root screen. Using the C-script I've attached.
The crash only seems to occur when the open Picture window has other picture windows open within it where scripts are running. If only one Picture window is open within it, it doesn't seem to be a problem, but if I have a Picture window open within the first Picture window I get the crash.
I'd appreciate any insights. I hope the issue is clear
No script is attached.
Hi. When using WinCC and the webnavigator, is there any way to force a script (Global C-script) to be executed on the server instead of on the...
5,956
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
61
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
55
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
113
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,586
