WINCC VBScript Dataset or Tagset?
teckhno2002
Nov 2005
Craiova
35
I have to work with several WINCC tags into several VBS actions. I read in the Siemens manual that I can use Global tags. I've tried to define a tagset into a procedure and use it into an action by calling the procedure like in the pictures below.
How can I do to make it proprely?
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
113
Hi, I tried this: HMIRuntime.Screens("Mainscreen.bottomwindow:bottomwindow").ScreenItems("btn_body").back.color = RGB(255,255,255)...
3,632
Hey guys. I am tyring connect from my HMI (TP1200) to a network location and open a file from a folder. The twist is I don't know what the file...
4,738
Hi! I have no experience at all with VB script but I think I might need something here. The issue is that we mainly have the WinCC Flexible to...
7,363
Hi, I get Error E429, ActiveX Object Cannot be created when running the following script on a TP700 panel: Sub Logging() Dim fs, f, DataSet...
3,059
